Re: Dreaded Antifreeze in Oil
Posted by El Toro on May 25, 2009 at 07:41:41 from (64.12.116.73):
In Reply to: Re: Dreaded Antifreeze in Oil posted by Larry Hardesty on May 25, 2009 at 07:13:19:
Remove the oil pan and apply pressure to the radiator. You only need about 5 psi and then look for any leaks around those seals. They get like an old shoe left out in the weather over time. If there's a leak the engine needs to be completely torn down and that area around those seals needs to be thoroughly cleaned of any rust or dirt. I would have the block cleaned & install new sleeves & pistons. Have the crankshaft measured for wear as it may be worn some. Have your local machine shop furnish the correct new bearings too. Get the head redone and it will be good for another 50 years. Hal
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
