Re: Dreaded Antifreeze in Oil
Posted by Larry Hardesty on May 25, 2009 at 08:51:51 from (74.38.148.140):
In Reply to: Dreaded Antifreeze in Oil posted by Larry Hardesty on May 25, 2009 at 06:49:59:
Well, I am guessing (and hoping)the o-rings. I think the previous owner just used the tractor in the summer as a rake tractor in the hay field. He probably ran water in it during the summer and then drained it after haying season and it sat empty over the winter. Then, I think it just sat for two or three years after the fellow retired before he had his ranch sale. So the seals probably had plenty of time to dry and detriorate. When I got it, I put antifreeze in it. I understand that antifreeze will get places and leak where water will not. So, it may not have leaked water but now just setting most of the time, it leaks antifreeze into the oil. I will try a radiator stop leak first and see what happens.
I had to replace the transmission oil. It had enough water in it that it froze up last winter. Looks like the old tractor might have been rode hard and put away wet (as they say) by the previous owner. Fortunately, the sheet metal is in good shape (although not a bit of paint on it). I would like to bring the old girl back to life and get her painted up. She was our main (and big tractor) on the ranch when I was growing up. The other tractor was a 1941 Farmall A, which I also have.
Thanks
Larry Hardesty
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
