Re: IH 666-Need Help!!
Posted by scotc on May 25, 2009 at 09:02:57 from (71.240.119.63):
In Reply to: IH 666-Need Help!! posted by BobHnwOh on May 21, 2009 at 15:50:21:
If the ramps in the expander are worn and you can find some HI-TEMP (copper based) anti-seize it can help til you can get new ones. Also backing up tends to snap them loose.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
