Re: Re: Farmall H low oil pressure problem
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bob M on April 11, 2000 at 15:10:48 from (171.208.56.127):
In Reply to: Re: Farmall H low oil pressure problem posted by mj delaney on April 11, 2000 at 11:11:42:
My Super H had a low oil pressure problem after it warmed up. Switched to 15W40 oil and found it maintains higher oil pressure than straight #30 when hot, yet permits reliable starting (on the stock 6 volt system) down to 10 deg and lower. Important to me since the tractor gets used mostly under winter conditions.
Post A Followup
: Re: Re: Re: Farmall H low oil pressure problem
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
