Super A coolant leak
Posted by Cue P. on May 26, 2009 at 14:15:53 from (74.10.243.130):
OK...when running my 53 Super A seems to have a slow coolant leak from somewhere around the gas tank bracket that bolts to the engine block. It drips off the bracket area and runs down the left side of the bell housing. The engine was rebuilt (new pistons, sleeves, gaskets). Is it possible for coolant to leak thru the gas tank bracket bolts (do they actually go thru the block or just into it?). Is there a freeze plug that high up in the block? Or is more likely a leaking gasket? Just wondering what i should be looking for since it seems i have to remove the tank and bracket to see whats going on...thanks for any help!!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
