Re: cheap starter swirtches
Posted by Bob M on May 27, 2009 at 18:24:24 from (74.74.133.11):
In Reply to: cheap starter swirtches posted by 2146 north on May 27, 2009 at 15:08:08:
Bill - The copper terminal button on the starter case under the switch acts as part of the starter switch. It wears each time the starter is used. Over time the button gradually wears down so even a new, factory OEM switch will not make proper contact. A new switch thus quickly burns out.
The only fix is to take the starter to a starter shop and have a new button installed - about $25 or so. With a new terminal button on the starter even a cheap starter switch will now give many years of reliable service.
You CAN replace the saddle (manual) starter switch with a solenoid. But you'll need to have a threaded stud installed to replace the starter terminal button so you can connect a cable from the solenoid to the starter. You also need a separate starter switch and more wiring - ie. more stuff to go wrong.
If the tractor was mine I'd stick with the original style manual switch...
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
