Re: Farmall H engine knock
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by medfarm on April 11, 2000 at 20:16:10 from (209.162.28.101):
In Reply to: Farmall H engine knock posted by Ron on April 11, 2000 at 19:38:53:
Ron
As per the previous post, check rod bearings by removing the rod cap. Since you said the engine has good oil pressure, the oil passages in the crank must be sealed by tight bearings or the spun bearing sealed the oil galley preventing a lost of oil pressure. If the valve train was faulty, the engine would run rough.
However, if a piston pin or connecting rod end on the piston were loose, oil pressure would be fine and the engine would run fine. Check external and accessory drive components. Good luck
Ray
Post A Followup
: Re: Re: Farmall H engine knock
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
