Re: Farmall H engine knock
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Greg on April 12, 2000 at 02:47:50 from (216.128.162.30):
In Reply to: Farmall H engine knock posted by Ron on April 11, 2000 at 19:38:53:
Put the pan and oil in, start up, start removing the plug wires one at a time, when you get to the right cyl the knock will stop. This will locate the place to inspect.
A double knock will mean the piston/ wrist-pin,
A single knock will be on the crank.
It takes .007-.012 clearance to make a knock .
IF the noise does'nt go away with the wires, it will not be crank related, then use a long screwdriver to your ear and locate the noise that way. A transmission funnel works good also , small end to your ear to find the general area, big end to your ear to zero in to the area. Hope this helps
Post A Followup
: Re: Re: Farmall H engine knock
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
