Re: farmall H oil pressure adjustment?
Posted by Janicholson on June 01, 2009 at 19:48:54 from (66.216.239.59):
In Reply to: Re: farmall H oil pressure adjustment? posted by binder dude on June 01, 2009 at 19:40:41:
With 40wt in it, I would look to clearancing and flat sanding the cover of the oil pump. I believe you will not adjust the oil pressure, you will repair a leak/ JimN
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
