My mystery is solved, and I thought I would post for future reference, so no one else has to go through my trouble.
There are 2 ball-joint inserts for the center steering arm. One is flat on one side, and rather thick 1/2" (thicker than the ones for the tie-rod ends). It goes at the bottom (end) of the blind side of the steering arm. Next, goes the ball-joint end of the tie rod. Next goes the double sided insert. Then install the opposite tie-rod. Lastly, install the set-screw.
The inserts for the tie-rod ends are approx 5/16" thick, and are flat on 1 side. One per side, with the flat end (of course) going into the far end of the tie-rod end.
I found that I had 1 of the tie-rod end inserts "missing" as someone in the past installed 2 7/16" washers as the ball joint inserts. I thought they were just spacers for wear. Turns out, they were intended to be the insert.
Went to the local tractor grave yard, Charlie Burgh's, and retrieved another insert.
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction,
... [Read Article]
