Posted by pete 23 on June 25, 2009 at 20:50:59 from (173.87.14.132):
In Reply to: 350 hydraulics posted by Bob 02 Martin on June 25, 2009 at 19:17:02:
The o-rings only keep it from leaking to the outside and do not hold the load up. Fit of spool to body does that. Your spool is worn, add a single acting check valve to solve your problem. If you are using a double acting cyl it may be leaking internally causing pressure to equalize on both sides of cyl and in effect the displacement of the piston rod is holding the load and pressures get much higher and even a good valve may not hold the load up.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
