Posted by mattofvinings on July 03, 2009 at 11:58:40 from (67.142.161.29):
In Reply to: Cub not running right posted by kennebunksawmill on July 03, 2009 at 10:19:05:
This sounds like my SA which sits outside under a tarp for now. It seems to get moisture inside the distributor cap.
I would take off the distributor cap, clean the point of the rotor and clean the brass posts inside the cap with a wire brush or scotchbrite.
I've been tearing my hair out over no-start conditions and twice it has been the ignition/distributor cap.
We're spoiled by the HEI automotive ignitions which will jump a 3/8" to 1/2" gap with minimal failure on every hit. The old tractor ignitions just don't deliver that kind of energy.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
