Re: 656 int. charging system
Posted by Janicholson on July 04, 2009 at 09:30:01 from (64.61.211.159):
In Reply to: 656 int. charging system posted by R Cummins - Missouri on July 04, 2009 at 09:13:38:
Charging all the time is a good reason to make some checks, but not a condemnation of the regulator.
With it running at 3/4 throttle, put a good analog (needle style) volt meter on the battery's posts. It should read 14.2 to 14.4 volts (lights off).
If it is, it is OK in the charging department. If it is 14.7 or more, I would replace or adjust (takes special procedure)the regulator.
If the battery has a partially shorted (bad) cell, it will charge all the time as well. The voltage will be as above, but the battery will continue to be trying to be charged.
Usually this results in loss of battery "water" in cells, and heating of the battery. Good luck, JimN
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
