Re the system. It is not a good idea to run that wire that way. Use a test light, and put the lead to ground. Put the probe on the Positive battery post (should be light) Put the probe on the Starter relay where the battery connects (should be light!) Put the probe in the terminal on that post where the wire attaches that goes to the dash (fat 10ga wire but not a cable) (should be light) Put the probe on the other end of that wire at the amp gauge, wire terminal, not the amp gauge terminal bolt) (should be light) Put the probe on the terminal where that wire connects (should be light) Put the probe on the other amp gauge terminal, LOAD side. (should be light) Put the probe on the wire going to the Ignition switch at the amp gauge (should be light) Put the probe on the bat terminal of the ignition switch Should be light. (I'll bet this wire has a corroded terminal or bad connection) should be light. The reason your gauge is going nuts is that the whole system is now partially through the amp gauge, and part way through the extra wire. Clean every terminal and check every wire in the Probing path and you will find the issue. Do not use that wire (it was an OK bypass test, but not a solution at all. JimN
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
