Re: Generator vs Alternator
Posted by Owen Aaland on July 18, 2009 at 14:18:42 from (65.174.247.87):
In Reply to: Generator vs Alternator posted by JMOR on July 18, 2009 at 07:27:19:
JMOR said: (quoted from post at 07:27:19 07/18/09) There might not have been from the factory, but 6v alternators are sure available aftermarket, even positive ground. They look just like the factory 12v/neg gnd, but use different reg & diode sets.
To change a 10SI alternator to six volts negative ground, all you have to do is replace the regulator. If you want to go from negative ground to positive ground you have to change the diodes.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
