Re: Farmall M Hydraulics- pics please?
Posted by Janicholson on August 02, 2009 at 19:11:11 from (64.61.212.247):
In Reply to: Re: Farmall M Hydraulics- pics please? posted by n9viw on August 02, 2009 at 12:51:27:
If the remote valve you have is a two way valve, it should have 4 ports. (one may be capped) does the valve connect to the top of the Liftall where the fill cap is? If so it might be a so called "christmas tree" valve with a built in return to the top fill pipe under the cap. If it just hooks to a bolted on bracket it should have a return hose connection to the reservoir. This return hose eliminates the need to push in the Liftall control rod to lower the cylinders. We will get it right. JimN
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
