Valve setting I do it this way others do a different system. It must be set cold first, so setting it twice (ore once) is normal The cold setting is .020" all valves. Take out the plugs. (turn it with a wrench, on the front nut) Set the intake valve on cylinder #1 (Front) when its exhaust valve just starts to open. Set the exhaust when the intake just closes. This is the two positions that can be seen on each cylinder to be as far away from a lobe on the cam as possible while still knowing where it is. The order is (front to back EI-IE-EI-IE) Repaired instructions, My appology!! Look at #1 valves, Turn the engine till the exhaust just starts to begin opening (moves) then adjust the intake valve. Rotate more until the intake just closes (just stops moving after having been open) and adjust the exhaust. Treat every cylinder (pair of valves shown above the same way, remembering they switch places between cylinders) I put a rag over the ones I have dobe to keep track of progress, and avoid mixing what I am looking at. JimN
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
