Posted by Janicholson on August 06, 2009 at 10:26:08 from (64.83.208.148):
In Reply to: Smdta elec issues posted by BOBM25 on August 06, 2009 at 08:59:35:
orrosion is caused by electron flow. Cleaning in a damp environment will temporarily fix it, but it needs a clear spray, or terminal spray on it to keep the moisture out. If it goes dead, thee is a drain on the system. It can be tested with a vlot meter set to 2 volts or lower. Disconnect one battery terminal, then check the voltage between the terminal, and the post. If more than .02volts, there is a draw. Disconnect things one at a time to find it. (reconnect as you go) JimN
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
