Posted by CNKS on August 08, 2009 at 12:39:54 from (216.144.104.128):
In Reply to: Help Please posted by Charlie Gascich on August 08, 2009 at 04:42:41:
If the tractor runs smoothly it is not the carb. Carb problems cause rough running. You may get slightly, emphasize the slightly, more power by opening the main jet screw 1/4 turn at a time. Otherwise with the engine warmed up and at WOT, turn the main screw in until it stumbles, then out until smooth, plus 1/4-1/2 turn. Idle jet at low idle, turn in and out until smooth, idle speed set to that it doesn't stall. My opinion is your grass is too tall. I can pull down an M with a 5 ft bushhog in heavy, tall weeds.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
