Re: Magneto vs Distributor
Posted by ScottyHOMEy on August 12, 2009 at 15:09:24 from (71.241.200.4):
In Reply to: Magneto vs Distributor posted by Retcol on August 12, 2009 at 14:38:50:
Magnetos are actually pretty reliable. There's a reason piston aircraft use them, though admittedly they do double up on them and everyting else in the egnition.
The H4 on the SuperA was a time tested and reliable mag, as well.
Only drawback I can think of is that on those rare occasions that somethng does go wrong there are things to a mag that not just everybody can fix, where a battery ignition distributor is pretty much a mechanical affair.
The big advantage to a mag is that you're not hostage to any of the things that can go wrong with a battery ignition (generator, cutout/VR, bad battery, a short anywhere, leaving the lights on . . . coil -- a mag has a coil, but it's not prone to the same kind of failure as the oil-filled cylidrical coils on the battery igntions). A magneto ignition won't die for any of those things going wrong and if you've got a hand crank you can start it and run it all day.
A little more difficult sometimes to fix, but less likely to fail and/or strand you is my view of a mag.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
