Re: Farmall Super A Oil Pump
Posted by Russ from MN on August 28, 2009 at 19:20:00 from (209.191.218.13):
In Reply to: Farmall Super A Oil Pump posted by Norm43 on August 28, 2009 at 15:06:26:
I recently had the one on our C apart because of low oil pressure, And it was exactly as someone suggested on this site, the cover was bent and part of the gasket was blown. As there are no Case-IH dealers in my area I experimented with plastigage and different thicknesses of paper. ended up with much better oil pressure using about .008 gasket. I think factory gaskets are .005 and mine had two. I sanded the oil pump cover flat, reinforced it and silicone's the gasket to the cover. Worked very well!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
