Posted by Jeff Z. on August 29, 2009 at 20:56:23 from (74.76.3.113):
In Reply to: poor circulation on H posted by maestro on August 29, 2009 at 20:27:58:
First make sure the bottom radiator hose isn't collapsing when hot. Make sure fan belt is tight enough. Get a new water pump.{Can't hurt} A good test for a bad radiator is to plug the bottom hole and fill with water. Remove the bottom plug and the radiator should empty with one big gush of water with some force behind it. If the water comes out slow or in spirts the core is plugged.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
