Re: super c hydraulic oil in crankcase
Posted by gene bender on August 30, 2009 at 06:01:25 from (67.55.227.88):
In Reply to: super c hydraulic oil in crankcase posted by carl Schreiner on August 30, 2009 at 05:16:44:
You need to pull the pump to see what seal is used some had a seal and some had an o-ring. Check the shaft as it mite be worn down where the seal goes and then you will need a speedy sleeve over that spot so the new seal can do its job. yOU can take it to any parts place and they can get the parts you need.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
