Farmall H Misfire
Posted by Bill47 Perry on August 30, 2009 at 09:52:34 from (64.12.116.73):
My H has a parial misfire after about 2 hours of running with a finishing mower behind it. Ignition is an IH magneto. What plug wire type, Copper conductor or other should be on it. It has Belden r3 marked on the wires. Is the coil in the magneto the most likely cause? Could it be carburetor float due to some gas being burned since starting with a 3/4 full tank? This problem is repeatable but seems to be getting worse. It started when backing up to turn around. With the throttle just above idle it would sputter and then pick up the load backing up. It then would sputter when going back to full load with the finishing mower and then smooth out. Any help would be appreciated.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
