Re: 39 Farmall Rearend
Posted by D Slater on August 30, 2009 at 18:10:14 from (72.65.136.11):
In Reply to: Re: 39 Farmall Rearend posted by cory smith on August 30, 2009 at 14:48:17:
Gear closest to front on the top shaft is the belt pulley gear box drive and its part of the transmission input shaft. next one back is the constant mesh drive gear also part of the input shaft, next is 4&5 sliding gear, next is 2&3 sliding gear, next back 1& reverse sliding gear.
On the bottom shaft starting at the front. Constant mesh gear, then 4,3,2 and 1 gears that drive the ones on top shaft. Hope we were on the same gear in the other post the 2&3 sliding gear.
They are called sliding gears because they slide back and forth on shaft when shifting. I may have a good gear, can look tomorrow if interested.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
