Butler Ensiloader 5615
Posted by deano4863 on September 25, 2009 at 15:41:17 from (76.31.47.68):
third party image
third party image
third party image
Any body know what this is? It came out of South Texas. I suspect that the crop (Milo,Corn,Hay?)what cut and raked and then this thing loaded it into a wagon. It is part of a reversed SM in another post. It doesn't have a cutter on it and has a canvas conveyer belt that runs it up and spits it out the top some 12-15' above ground. It is powered by a PTO shaft that come for a gear box in palce of the belt pully assembly. This this have any value?
It's here because it's part of a SM. I will post it also at implement alley.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
