My understanding is that the newer seals don"t have to be as thick because the synthetic seal material has better performance. Some of the original seals I"ve removed from my tractors appear to have been leather. While I"ve heard of using two seals to make up the original width, that apparently is not a good idea because a seal needs to have lubrication to prevent it from drying out. In a tandem arrangement the outer seal doesn"t see any oil. A secondary advantage with the narrow seal is that it gives you a little bit of option to now pick the best shaft surface, in case there has been some deterioration.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
