Re: Edit to above
Posted by scott#2 on October 11, 2009 at 09:27:16 from (151.200.15.212):
In Reply to: Super A wont start posted by scott#2 on October 11, 2009 at 08:41:44:
Thanks for the reccomend on the soak, pulled the v/c off, found a bent push rod and 3 stuck valves and one partially stuck. To free them up, I tapped them down as far as they would go (one at a time), one came back on spring tension, the other 3 needed to be pushed up and down a few times to free them up, their still sticky so will stay on them with soaking.
What I did was tap one all the way down and slowly hand turn the engine and let the piston push it back up a little and repeated this until I could eventually pry them back up with a big screwdriver under the retainer, then repeat on the other ones. So far looks like I got lucky by getting to them before they were really rusted up, never had this happen before. It stays outside with the stack covered, guess weve had more humid days than usual around here. Moral of story, run your stuff every couple months.
Rings might still be stuck, need to do one thing at a time.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
