Re: farmall belly pump knocking
Posted by pete 23 on October 19, 2009 at 07:51:00 from (173.87.8.73):
In Reply to: farmall belly pump knocking posted by redblood on October 19, 2009 at 06:04:44:
Often times the spring in pump breaks going through the gears, not good, but you will feel a definete difference on the lever if it broke. Don't over look loose bolts holding pump in and as the transmission counter shaft is what drives pump you could have a trans bearing or gear problem so if and when you do get time to drop pump, see if noise is gone with out pump in . As long as pump still works good and probem is for sure in pump I would take it apart and you may have to touch up the gears to eliminate the racket.
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
