1. It was that color because it has moisture in it. I don't know any reason why "limited slip" gear lube would not be OK. It would sure be better than the lube that is water contaminated.
2. That is only an estimate. It may be a tad high for a total. NO! it does not all go in the hole in front of the shifter. The transmission fill check plug is on the lower left-hand side of the transmission, behind the left side brake rod. It looks like a small pipe plug. Put oil in until it starts to come out that hole, then stop. Each final drive has a plug in the casting toward the fron of the drive. That is where you both check the level and add more. The only way to drain the drive is to remove the pan on the bottom of it.
3. If you over fill the transmission, it will leak out the seals where the differential shafts exit the differential and run out small drain holes in the bottom of the differential shaft housing.
4. Thos are the holes that oil will come out if you put too much in the transmission. Do Not plug them.
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction,
... [Read Article]
