Since we're going to talk about technique, I too would avoid that area with the tractor like the plague. Even with duals you're going to at least tear up the area, and probably get good and stuck.
What did you intend to do to improve drainage without digging a trench? Other than re-grading the entire area... Those are really the only two practical choices, and as someone said, you can't work mud.
Really your only choice to remedy the immediate problem is a trench. That may be better handled by a backhoe or trackhoe, something that can sit up where it's high and dry and reach down in to dig the ditch from the side, much like a roadside ditch. You'll need to hire some heavy equipment to un-stuck the 300 after you bury it, so you may as well hire them outright to do the actual work.
Later on in the spring you can bury a 4" drainage tile and re-grade the area.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
