First is the polarity of the coil. If it has an alternator, it is very likely a negative ground battery and charging system. This means the coil negative should be grounded (through the distributor/points) Second is the timing. With #1 on TDC, The points should just be breaking, with the rotor pointing to #1 wire terminal in the cap. If these are right, pull the coil wire away from the cap, and place it 1/4" away from the block. Open the cap, and use the tip of a screwdriver to open and close the points. If there is a nice blue spark it should run. If not suspect the coil. JimN
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
