Posted by rustyfarmall on November 05, 2009 at 09:23:04 from (209.152.78.140):
In Reply to: engine oil sludge posted by Andrew Z on November 05, 2009 at 09:15:51:
I will suggest removing the oil pan, clean it thoroughly, and re-install. A new gasket for the oil pan will cost you around $10 or less. Refill with fresh motor oil, but you might want to replace 1 quart of oil with 1 quart of "Rislone". Run and use the tractor for awhile and then change the oil and filter again. You might need to do several oil and filter changes, but eventually the sludge will be cleaned out. I think some of the guys are now using "sea foam" instead of the "Rislone"
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
