I cant say sitting here what solenoid you have so can only describe how a typical Ford type 4 terminal (2 big 2 small) solenoid works.
When in the "START" position a wire down from the IGN switch needs to send 12 votls to the solenoids small (S) Terminal (AND THE SOLENOIDS METAL CASE NEEDS A GOOD FRAME GROUND TO WORK) and the solenoid should engage click and pull in so she cranks.
The Ford Solenoids also have another small terminal labeled I which is hot ONLY WHEN THE SOLENOID IS ENGAGED. It can be used to by pass any ignition balalst resistor for a hotter starting spark in 12 volt tractors that use a 6 volt coil plus external ballast. Its (I terminal) not used if you have a 12 volt coil and dont use any ballast
Soooooooo insure the solenoids metal mount has a good frame ground,,,,,,,,,,,wires its S terminal to the IGN switch so when the switch is in START 12 volts is present
NOTE THIS IS FOR FORD TYPE SOLENOIDS if you have another solenoid let me know
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
