Re: Charging questions
Posted by Janicholson on December 04, 2009 at 18:14:27 from (64.61.211.205):
In Reply to: Charging questions posted by J Wilbur on December 04, 2009 at 16:42:12:
By 2 wire, I assume you have connected the #2 terminal to the output post (Big terminal) this sensor wire controls the voltage output at the alternator. If it is connected well, I suspect the regulator inside the alternator to be out of spec.
Typical voltage at the battery terminals at 1/2 throttle with the battery charged is 14.2 to 14.6 volts. If you operate a system much higher than 14.6 (maybe as much as 15) it will reduce the life of the battery. The exception would be short run times and cold weather. In which case the drain on the battery would compensate for high charge rates.
Before replacing parts, clean all connections to the battery and ignition to Alt and bat to alt wires. Special look at the #2 terminal to output post is warranted. Good luck, JimN
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
