Posted by mkirsch on December 08, 2009 at 05:18:26 from (64.80.108.57):
In Reply to: 1952 Cub 12V posted by Kennebunksawmill on December 08, 2009 at 02:56:18:
13.8-14.5 Volts is correct output for an alternator. It needs to charge the battery, and it can only do that by generating a higher voltage than the battery has. Electricity only flows "downhill" from a higher voltage to a lower voltage.
The coil says "External RESISTOR" for sure. Look for a white porcelain device connected in the wire running from the ignition switch to the + post on the coil. The white device is a resistor. If you find one you are okay. Otherwise you need to get one and add it in the wire between the ignition switch and coil. Most 1960's and early 1970's cars had them, so you should be able to walk up to the counter at NAPA and ask for a "ballast resistor" for an ignition coil off an old muscle car.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
