Posted by Mark on December 10, 2009 at 14:26:43 from (67.140.133.18):
Well the snow is blowing, it"s hateful outside and a good time to fix the leaks and squeaks and rattles.
What does it require to replace the rear main seal in a Super C? I"ve got a major leak at the very rear area of the oil pan and while it may just be a pan gasket...I fear the worst.
Do you folks still advocate the use of a pan gasket as opposed to "blue glue" silicone? I"d expect most would prefer a gasket but maybe the silicone works as well....I don"t know and so, I"m asking. I recall yanking the valve covers off a 1979 Olds that I had bought new....and found that they had used a black silicone which worked fine.
I"ve got to replace the belts on my SA and SC and I have never performed this job before either. The fan bearing is shot on the SC as well. How does the fan come off....do I remove the nut behind the fan bearing or just remove the fan mount from the block with fan attached?
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
