Posted by Matt Canaday on December 13, 2009 at 22:16:43 from (74.34.118.14):
Super C Timing Setup
Hey guys, for those of you who want to time your super c dynamically, I’ve made a few notes about what I did. By the way, by dong this I found out that my timing was advanced way too much and my distributor timing weights were not working, basically they were almost froze.
First I made a pointer:
Then I downloaded a paper timing wheel, it was a jpeg file (just do a google search) and then sized it to 5 ¾” using word to match the size of the crank pulley, printed it, cut it out, and glued it to some cardboard. I then used doubled sided tape to stick it to the pulley.
Then I purchased a piston stop for about $8.00, this is essential to get accurate TDC. A very good discription of how to use a piston stop to get TDC can be found here: http://www.4secondsflat.com/TDC.html
After finding exact TDC I marked it with a file and then filed a mark for every 5 degrees before TDC, I also did one for 16 degrees because this was my target according to the manual
The Manual
I then painted the marks, below is what 16 degrees before TDC looks like.
I needed an accurate way to get 1350 rpm, I couldn't use my old school tach meter because I have also installed a pertronix electronic ignition, so I purchased a laser rpm meter for under $20. To get a more accurate rpm I stuck an old saw blade between the throttle and the serrated teeth so I could fine tune my RPM.
This little unit comes with reflective tape, I just put a piece on the pulley.
I am so glad I did this little project. Very worth it.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
