The only parts available are O-rings, gaskets, and the garter spring. The valve body and spool are a select fit and must be kept together as a set. O-rings should correct external oil leaks. If the problem is not holding a cylinder in place under load there is not much you can do to the valve to cure it. If your cylinder is not leaking that problem is almost always caused by excess internal leakage between the spool and the housing.
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction,
... [Read Article]
