You can swap all those tranny gears around except for the constant meah gear. There is only one of those from SMTA to 660 so there is no point in changing that. What you have to bear in mind is that all the gears have the same pitch (except constant mesh gear). This means that any tranny gear set has to add up to 73 teeth. D Slater has already told you about the bearings and their retainers.
Go to caseih.com and print out the transmission internals for 560 and either SMTA, 400, 450. Figure out what you want to do and write down the part numbers.
You want to go faster. I did just the opposite on a SMTA to go slower. I used 560 differential gears and 560 first gear. Speed in first gear is about .75 mph vs 1.5 mph stock using the TA. I probably have all the gears you need to go faster in all gears. The jump in second and fifth won't be as large (in percentage) as the others.
Click the link below for a thread on gear ratios and speeds.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
