CtryBoyInMT said: (quoted from post at 06:27:32 12/20/09) The hydraulic block on the tractor requires a 7/8"-14 "90 Duro" O-ring fitting.
The standard female coupler from the factory is pictured. If it have international stamped on the collar, it is a safeway adapter. This will accept safeway and pioneer style male couplers.
If you were able to remove the adapter from the female coupler, it is just a 7/8"-14 x 7/8"-14, 90-Duro O-Ring adapter.
I'm still unclear what you're trying to replace or why, so I'll cover both. You can get both the 90 Duro O-ring and the internal 70 duro O-ring inside the female coupler if either of those leak. If you need a new Female coupler CNH 374780R92 is the only one I've been able to find. You will need to use the 7/8"-14 x 7/8"-14, 90-Duro O-Ring adapter as the coupler is female thread. If you can't find the factory replacement, you can use a straight adapter 7/8 O-ring to pipe. These are expensive puppies, so I just replace them with OEM.
If you can't get them to mate, A NPT standard pipe (what ever your loader hose requires) to safeway/pioneer coupler will work, as pictured above.
Thanks for the good info.
I was making it too hard:
I was trying to reuse the old female coupler (international stamped on collar). So I just got a couple of pioneer male hose fittings (8010-4). That worked on one hose, but the other hose is an Oring end. I think there was a male end that pioneer makes which will convert the Oring to std male tip. We'll see. I'm sure I'll be taking a shower in Hytran before this is all done.
This post was edited by Rtkman706 at 07:20:32 12/20/09.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
