Based on my experience with my Super C, it sounds like the starter is locked. Loosen the studs holding the starter just enough to wiggle the starter a little bit. Or--even before doing that, tap the starter with a wrench.
Locked starter is a common problem with C's and Super C's. Can be an indication that you need a new starter drive or ring gear or both.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
