Is the switch pulled out all the way? Do the lights Dim when you pull? Do you have voltage to the saddle? Could be bad a bad ground, Bad switch, bad wire, bad starter/ starter stuck on ring gear.
Check for voltage first. With the switch on, test for voltage at the saddle if you have it it is the starter or bad ground remove and bench test starter and clean both surfaces reinstall and try again. If not work your way back to the switch. If you have voltage before the switch and not after, bad switch, if voltage after the switch, bad wire. No voltage before the switch, bad wiring from there.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
