Re: Farmall C will not crank over
Posted by Jocephus79 on December 27, 2009 at 11:49:25 from (70.246.173.133):
In Reply to: Farmall C will not crank over posted by Beatles65 on December 26, 2009 at 17:13:00:
I call Bull &*%$ on this one
I'll bet its the saddle switch on top of the starter. Clean the contact area in it and it should be fine.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
