Re: Bleed air out of diesel fuel sys.
Posted by Marty from MN on January 12, 2010 at 15:55:57 from (71.34.13.145):
In Reply to: Bleed air out of diesel fuel sys. posted by Darrel Christensen on January 12, 2010 at 15:06:04:
Not sure if this is the "correct" way to do this or not, but crack open the fuel lines on each injector and turn it over until you get fuel coming out of each line. Then retighten the lines.
I've used this method on several diesels and has always worked for me.
Before you start this, you may also want to check fuel flow on the engine side of the fuel filters.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
