Makes it hard to say, unless you can find a newer manual that deals with the pneumatic tires. (Who knows what IH/P&O might have done with dimensions on the running gear when they switched over?)
If you can play with your levers to get it to
a) run level at your desired depth b) lift clear for turns when working and b) transport okay
I wouldn't see the point in switching them. If you were to change out the tires on them, to some recommended sizes, then you might want to look at switching them back across as part of that project.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
