Re: Farmall 460 hydraulic leak from bottom of TA case
Posted by pete 23 on February 12, 2010 at 11:11:29 from (173.87.0.197):
In Reply to: Farmall 460 hydraulic leak from bottom of TA case posted by Alex Tolmachoff on February 11, 2010 at 20:55:38:
With out a TA you still have seals inside and taking the top cover off you would be able to see where it is leaking from. As for hydraulic staying on high pressure, check your aux valve double to single action setting to be sure pins or not broke or bent allowing valve rotate too far, if that is ok, you most likely have a plugged orfice screen in regulator valve assembly.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
