update: Cleaned up the pilot valve and everything seems ok. Just need to buy a new o-ring boss to JIC fitting cause someone used a tapered pipe thread to JIC fitting when the thread is a boss. It didn't leak but I should fix it right.
I tapped the body of the flow divider on my vise and the flow divider valve and spring popped out. Cleaned it up and looks ok.
I pried the safety relief valve out the back of the flow divider with some needle nose pliers. I could blow through through the little hole in the end. Stuck the other end in the vise and unscrewed the screw. Removed the screw and spring. The needle assembly would drop down to the holes in the middle of the valve body but wouldn't come any further. Cleaned it all good with carb spray including through the needle and seat. Installed the spring and screw and I couldn't blow through it any more.
Guess I'll buy some orings and find out on Sunday if the flow divider relief valve was the problem or not.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
