Posted by Owen Aaland on February 13, 2010 at 05:47:57 from (65.161.86.2):
In Reply to: charging options posted by mike paulson on February 13, 2010 at 02:35:57:
If your battery is good and it is starting well for you you might consider installing a six volt negative ground alternator. I would wire it for a three wire hook up, install a diode in the excite wire, reverse the wire on the coil, ammeter, and battery. Then if in the future you would want to convert it to 12 volt all you would need to do is change the battery, regulator, and light bulbs, and add a resistor to the coil.
Alternators are simpler if you stay with negative ground and the only difference between the six volt version and the twelve volt one is the regulator.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
