Re: '53 Super A oil leak from front crankshaft seal
Posted by steve alderman on February 13, 2010 at 11:33:50 from (68.81.233.34):
In Reply to: '53 Super A oil leak from front crankshaft seal posted by aquanosis on February 13, 2010 at 10:59:24:
the worst part is getting the pulley off the crank you will need a clamshell puller with any kind of luck you should be done in 4hrs
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
